Disabling The VATS System? - FirebirdV6.com/CamaroV6.com Message Board
  • Disabling The VATS System?
    Im installing a new remote start / security system tomorrow in the 'bird and I didnt order any sort of bypass kit. My question to you guys is, what wires do I have to connect together to disable the VATS system in my car?
    Im not worried about theft or anything (And even if it was a problem around here I've got the starter kill relay to install with the alarm). It would also be nice to be able to goto the hardware store and have a spare key cut without having to get a blank from GM and paying through the a**.
    Anyways, any insight on this is muchly appreciated.
    Representin' Team Red In The North
    Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
    Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
    Black/Red '02 Honda CBR 954RR Fireblade
    Re: Disabling The VATS System?
    first thing your not going to just cut and tie a couple wires together there more involved heres a link that will tell y how to do it
    http://shbox.com/1/vats_bypass.jpg
    http://shbox.com/1/4th_gen_tech2.html#pass_key
    you will need a ohms meter to do this
    you can get the restiors you need at radio shack
    96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
