Electrical problem - FirebirdV6.com/CamaroV6.com Message Board
Electrical problem
  • Electrical problem
    Ok here's the deal. Every time it gets cold, I have difficulty starting. At first I'll try to start and I get nothing. Then I'll let it sit with the key in the "on" position, and I hear a constant very very fast paced ding-ding-ding-ding-ding-ding-ding(you get the point) coming from the BCM. After 1 or 2 minutes of this the ding slows down to normal (like how it sounds when you can start normally) and I am able to start. Is this a bad BCM, or bad PCM connections? Or is it just because its cold? Can anybody help?
    [ December 29, 2003: Message edited by: JohnC ]</p>
    White 1998 Firebird M5, Suncoast WS6 hood, Chrome 18\" C5\'s, beaver tail wing, 2 15\" Kicker Comp VR\'s, ect.
    Have you had your battery checked lately?
    2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
      Bad battery or poor terminal connections are probably cause. Replace the battery if is original for your 96 and make sure you clean the terminals with baking soda and water after removing the boots. Get new battery terminal bolts too.
      180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
        I'll double check the terminals, but the battery is a red top optima and its like months old.
          Terminal connections must be perfect. I have had trouble and traced it down to that problem. No start unless they were perfect.
