Okay got the code read, and im misfiring on cylinder 2. Plug wire seems to be okay. Have not taken the plug out yet, but a friend was telling me to unplug my MAF with the car off. Then start the car and the computer will switch to SpeedDensity and then drive the car to see if I still fall on my face at throttle. If I was having misfiring issues w/ SES Light and it tells me that im misfiring on cylinder 2. Could MAF even be related?
Cylinder 2 Misfire
Cylinder 2 Misfire
30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>Tags: None
Re: Cylinder 2 Misfire
If you unplug your MAF your going to have even more problems or rather your ses is only going to stay on because it's not sensing the MAF. The simplest thing to do is change the plug. Or depending on long it's been just do a complete tune up. Don't unplug a sensor to compensate for a $2 part.Let's flip a coin. Heads I get tail, Tails I get head.
I think he is trying to make you run in SD mode to see if the MAF is making you lean.
To check a plug wire, run the engine in the dark. See if you see any sparks coming from that wire. If you get shocked it'll tingle (dont know if you're into that sort of thing ;) )
Have you been racing? maybe plug...
Otherwise it could be the coil, ICM, etc..2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by slow6I think he is trying to make you run in SD mode to see if the MAF is making you lean.
Otherwise it could be the coil, ICM, etc..30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
Originally posted by 1SL1k30thCamOkay got the code read, and im misfiring on cylinder 2. Plug wire seems to be okay. ....
the plug wires are just so common to go bad on the 3.8/3.4 motors and farily easy + cheap; that I always focus on them before jumping into other stuff that can get costly
[QUOTE=slow6]
QUOTE]
it doesn't hurt that much unless your working on a boat with one foot in saltwater
Originally posted by smithtimit doesn't hurt that much unless your working on a boat with one foot in saltwaterLet's flip a coin. Heads I get tail, Tails I get head.
I'm sure he does. Dangerous cause of all the amps.
I wouldnt say that its common for spark plug wires to go bad when you take care of them:
1) tie them off with twist-ties
2) protect them from the header's heat by using thermal protection
etc
If ya dont take CARE* of them they will go bad quick
edit: added "CARE*"Last edited by slow6; 01-22-2007, 06:07 PM.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
I've never had a problem with my wires/plugs going bad.......it always seems like it's the front coil pack that goes bad. And from all the threads I have read and stories I have heard about everyone else having this same problem, you think they would have did a recall on this.
And yes, it would hurt if you have one foot in salt water when checking for spark on a boat.
33k miles and not 1 bad coil2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by youngscHave any personal experience with this?
