egr bolt broke - FirebirdV6.com/CamaroV6.com Message Board
egr bolt broke
  • egr bolt broke
    well guys i was trying to clean my egr up and the bolt to the egr tube that goes to the exhaust manifold broke off in the manifold.it is too cramped to get a drill in there and not to mention i have never had to tap anything before so i am lost.any suggestion?i tryed jb welding the the thing that holds the pipe down to the manifold(i know,i know ) but it is leaking badly and that is with the vice grips still attached to it.any idea what i can do to fix this?the car is running ruffly and i have a cel.i don't have a checker sorry.i really don't wanna drive to autozone with it leaking like this.any ideas guys?
    thanks in advanced.
    Re: egr bolt broke
    copper RTV
      Re: egr bolt broke
      I think Dan means block it off?
      Prettiest whores at the fair FTW!!
        Re: egr bolt broke
        will the copper rtv hold with no bolt holding it?
          Re: egr bolt broke
          I doubt it will hold. Most likely blow out. If you can't get at it to drill it out you might have to take the manifold off and then do it. Kind of a pain I know, or try moving some things around that area to get in there with a drill
          http://www.bowtiev6.com/
            Re: egr bolt broke
            i got a crappy frill anyways (6.0volt)it gets hung up drilling the the fiberglass in the doors. i wonder if the dealer would charge and arm and leg to do this?
            what do you think?
            mostly i am scared of breaking a blot off in the head.
              Re: egr bolt broke
              you could also try an exhaust shop. Take it in and explain to them what happened. See if they will take the manifold off and drill it out and reinstall it for ya. Or maybe they can get in there as well. Dealers are generally a bad place to go pricewise for work unless you have a warranty
                Re: egr bolt broke
                i'll try that out,thanks man.i will let you guys know how it goes.
                  Re: egr bolt broke
                  just delete it and weld it shut. thats what i did
                  1997 Camaro LS1 RS
                  1994 Camaro - Sold
                  1999 Trans am Vert - Sold
                  A Few Mods....
                    Re: egr bolt broke
                    that seems like a good idea also. thanks.
                      Re: egr bolt broke
                      what year car is it?
                        Re: egr bolt broke
                        96 model,also would a small exhaust leak like this make my car idle funny?it drove fine but idle is 800-1000 and bounces slightly.i clean the egr itself,is this a no-no?
                          Re: egr bolt broke
                          Yes, that would make it idle slightly off the norm. And more power to you cleaning the egr, I clean mine all the time and so do a lot of other people. No problem there as long as you leave no residue or use the wrong type of cleaning solvant.
                            Re: egr bolt broke
                            it depends on where the exhaust leak is...
                            if its anywhere upstream of the stock NB sensors, yes, it will make the o2 sensors read wrong. Now, on the downstream side of the stock NB sensors, I would say its bad to have a leak up to like 9" downstream of the stock NB o2.
                              Re: egr bolt broke
                              okay so here is the verdict,i took it to autozone.i definetly have a leak i can hear it sputtering around that area and i don't think it is anything else.i have to codes.one is directly related to the egr not sure about the others.
                              codes are-
                              P0406-the voltage signal from exhaust gas recirculation sensor "A" is too high for the current engine operating conditions.(related to the egr but what the heck does this mean?)
                              P0441-the purge flow in the evaporative emission control system is incorrect for the current engine operating conditions.(what does this mean?)
                              okay i have no clue what this means but i think i need a new egr?anybody know for sure whats going on here?i used just water,q-tips,and a terry towel.i just got the most of it out,i didn't shine it to perfection or anything.i did clean inside of the egr,but i didn't drown it.
