Fuel Pressure Regulator.... - FirebirdV6.com/CamaroV6.com Message Board
  • Fuel Pressure Regulator....
    Will this work for my 97 Camaro M5?
    Sorry about that guys heres the thing in question.....
    http://www.jegs.com/cgi-bin/ncommerc...22&prmenbr=361
      That could be made to work, but it would take A LOT of custom fabrication. You would have to adapt the stock lines to -6AN fittings first and then disable the stock fuel pressure regulator (FPR). If you didn't disable the stock one, you would regulate it with the Aeromotive one and then the stock one would kick in as well so you would be contradicting yourself.
      Besides removing the FPR completely, I do not know of a way to disable it.
      Actually, I guess you could remove the vacuum line from the stock FPR and run it to the Aeromotive one, but I do not know how the stock FPR would react to that (if it would allow fuel flow or how it would regulate).
      I think really, the biggest problem is adapting the lines. Going to a -6AN would be tricky off of the stock plastic fuel lines.
