Ok, here's the deal: sometimes when engine gets load (clutch is released slowly) car shakes... shifting gears - clutch engage - shakes.... only does so when it's hot. Cold (even if just stats for 10 mins) it doesn't do that, so therefore it's not heavy mechanical (such as bearings or warpage). I was thinking ingition... I was thinking of redoing whole 3 coils, wires and all plugs. Did anyone change it all out and noticed any diffrence? It seems like engine is not SMOOTH running, but kinda choppy. No SES, no misfires. I had one coil crap out recently.. you think it's time to change out other 2? 40k miles on the car. Thnx
Shaking!!!
Does it only do it in a certain gear, or all of them?
I'd change the plugs and wires first and try it out then go for the coil packs if it keeps up you may have a bigger problem.
good luck!04 black comp G GTP<br />*sold* 2000 z28 6speed <br /><br /><a href=\"http://www.cardomain.com/id/extinctls1\" target=\"_blank\">http://www.cardomain.com/id/extinctls1</a>
