Between my last post and this one I have been racing and an increasing concern of mine is how terrible ly traction is. My car is basically stock and when i gun it i spin the tire for quite a while. I was wondering how many of you have this problem and also what the practicality of buying a rear end with posi would be? It is a big problem and i really want that traction. Might traction bars be enough to correct this problem? If i were to find a new rrear end with posi at a junk yard (say from off a z28) could i just slap that on my car and go? Might i just want to stick with just a new rear differential?
Rear Differential
<blockquote>quote:</font><hr>Might traction bars be enough to correct this problem? If i were to find a new rrear end with posi at a junk yard (say from off a z28) could i just slap that on my car and go? Might i just want to stick with just a new rear differential?[/QB]<hr></blockquote>
by traction bars do you mean LCA's? im pretty sure track bars are for cars with leaf springs (i know a lot of 4th gen f-body guys and none of them have track bars) LCA's will help though
if you get a Z28's rearend make sure that its from a manual car so you wont get stuck with a 2.73 gear. however when you take a rearend from a manual car you will get a 3.42 gear, so your spedo will have to be recalibrated
or you can get a take off LSD diff for around 100-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
you can get one from a auto as well, just either make sure its from a SS/Ws6/Hawk, as they have 323's or check the door for the codes "GU5"
Ryan.1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
<blockquote>quote:</font><hr>Originally posted by StudlyCamaro:
or you can get a take off LSD diff for around 100<hr></blockquote>
i have never heard of LCA's. What exactally does that stand for? And where can i find this differential you speak of?There is fast, too fast, and way too fast. Way too fast is almost fast enough.
<blockquote>quote:</font><hr>Originally posted by CoreyCamaro:
i have never heard of LCA's. What exactally does that stand for? And where can i find this differential you speak of?<hr></blockquote>
LCA = lower controll arms, all the sponsors should have them
you can get an LSD cheap from AMM (check the sponsors section)-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
So what might some of you recommend as the cheapest way to get either posi or just a good grip on the ground (something that might be easy enough to instal for even a car illiterate kid with a chilton guide)? Keeping in mind however that I will me modifying my car and I most likely will want posi. Also, does anyone else have this problem because I have descent tires but my grip is just terrible and my car is stock save a k&n filter?There is fast, too fast, and way too fast. Way too fast is almost fast enough.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
