Ok, so my car has been acting up for about 12 days now. I changed my old spark plug wires to msd b/c of a misfire code but the new wires didnt help at all. I also checked my ICM and it's good. So after some research I think my fuel injectors or fuel regulator has gone bad b/c there's a strong fuel smell when it starts.
So my question is if i were to buy a set of 6 Accel Fuel Injectors 24Lbs do I have to tune my computer after installation? Or can I not worry about that? Thanks.
<a href=\"http://www.cardomain.com/id/fuelslut98\" target=\"_blank\">http://www.cardomain.com/id/fuelslut98</a><br />Peel out man. C\'mon just do it.
Spark plugs were the prob with my car. Mine was so bad it was lacking power and started bucking really bad. PLugs and wires are the easiest cheapest fix.
Let's flip a coin. Heads I get tail, Tails I get head.
I had a fuel injector clog on me last winter after storage, but that was really noticeable (it would barely rev past like 2K). But yea like everyone else said, change the plugs. AC Delco iridiums or NGK's
Yeah, I would definately change your plugs and check your coil packs first before looking at changing your fuel injectors (and why not just clean your current ones?)
Thanks for your responses. Im gonna go ahead and change my spark plugs first before doing anything. The reason Im so bent on thinking it could be the fuel injectors is that when I start up my car there's a strong fuel smell. Hopefully its the spark plugs b/c I read its a pain to clean the injectors.
