Bad Coil Pack??? - FirebirdV6.com/CamaroV6.com Message Board
Bad Coil Pack???
  • Bad Coil Pack???
    My car has an intermittent misfire. When it happens the car will hardly move. It happened today and I opened the hood to take a look. I was tapping around by the coil packs and the misfire stopped. I really think it has a bad coil pack but I do not know which one. This is a 93 Firebird 3.4L which had OBDI. The check engine light does not work. Is there a way to figure out which coil pack it is?
    If I get an OBDI scanner does that just flash the check engine light or does that actually give me the codes?
    Thanks...
    Re: Bad Coil Pack???
    pull the plug wires off 1 coil pack at a time (make sure you shut it off first or you will shoch the crap out of you self). thats how i found it on mine.
      Coils are notorious for going out on 3.4's and 3.8's. I replace at least one coil every 3 months or so.
        How hard are they to change? Do they just come off by removing the 2 screws that I see on each side of them. It looks like the one on the bottom could be a bit of a pain to get the screws out.
          deff sounds like a coil,people are always complaining about them i have a 95 3.4 ive put over 60k on it with out any coil trouble and my friend has put more than that on his with no problems from the coils
            they may go out frequently but as often as you all are describing it I would say you have another problem.
            Let's flip a coin. Heads I get tail, Tails I get head.
              My car has 132,000 miles on it and they appear to be the originals. It has not acted up since yesterday morning so I am going to keep an eye on it and when it happens again I will try to figure out which one it is.
                Easy, take off the 2 plug wires (they can be a pain) and keep note of which post they go to. Unscrew 2 screws, pull the coil off, set new coil on and snug the screws up. Replace the spark plug wires and you are good to go :tup:
                  you're right. Tech shouldnt have a coil only last a max of 3 months
                    As previously mentioned, my check engine light does not work. I do not know why. Will either of these OBD 1 scanners pull the codes for my car, or do these scanners just flash the check engine light. I need a way to pull the codes without having to rely on the C/E light.
                    Scanner #1
                    Scanner #2
                      what the **** does that mean?
                        It means your coils should last longer than a maximum of 3 months.
                        I suspect something else is wrong to make the coils only last less than 3 months.
                          Strange. My grandma's grand am is always in the shop for a missfire, usually coils and she has a 3800. I remember in a thread a while back a lot of other's have coils go bad frequently.
                            Mine has about 90,000 miles and still have the stock coils.
                            2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
                              point proven, thanks
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
