I recently just got a '02 Camaro, and now am looking into changing out the thermo along with intake. I've got two questions though about installation. Which temp thermo (180, 195) is stock in a 2002 model? And where and how do I install this 18k ohm resistor, so to not set off a code? Thanks in advance.
question about thermo's
Info about this stuff is in one of the links at the top of the page.
I believe the code is only set if you're using a 160 thermo.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
1997 when i got it, it had 195. i use 160 or 165, i forget what is was, But i have had no problems what so ever.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
i think in an 02 you can use a 160* without setting off a code, but correct me if im wrongK&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
