Throwing codes - FirebirdV6.com/CamaroV6.com Message Board
Throwing codes
  • Throwing codes
    P0113 Intake Air Temperature (IAT) sensor circuit high voltage ok so what do I do about it. And I got a P01404 I don’t know what it is.
    Re: Throwing codes
    check your IAT sensor and make sure the wires are not cut or broken loose. Also make sure the sensor is into the intake good and nothing is obstructing airflow over it
    http://www.bowtiev6.com/
      Re: Throwing codes
      only advise is to just look at the sensor to see if it is damaged, look at the wiring really good and try to follow it as far as it goes and look for damage. if you see nothing out of the ordinary, replace it. I need my tech 2 hooked up to really diagnose that bad boy
      and if you didn't know, this is the IAT Sensor
      Originally posted by 3800Y87
      P01404
      no such thing
      2000 3.8 A4 Pewter Camaro
        Re: Throwing codes
        So y would it give me a code that doesnt exist. Ur say the code reader was wrong?
          Re: Throwing codes
          DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
          closest i could find
          Follow me!
          Or this
