P0113 Intake Air Temperature (IAT) sensor circuit high voltage ok so what do I do about it. And I got a P01404 I don’t know what it is.
Throwing codes
Re: Throwing codes
check your IAT sensor and make sure the wires are not cut or broken loose. Also make sure the sensor is into the intake good and nothing is obstructing airflow over it
Re: Throwing codes
only advise is to just look at the sensor to see if it is damaged, look at the wiring really good and try to follow it as far as it goes and look for damage. if you see nothing out of the ordinary, replace it. I need my tech 2 hooked up to really diagnose that bad boy
and if you didn't know, this is the IAT Sensor
Originally posted by 3800Y87P01404Last edited by BLLDOGG; 01-31-2007, 05:42 PM.
Re: Throwing codes
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
closest i could find
Follow me!
Or this
