i have a squeel sound under the hood i dont know if its the belt pullies or powersteering. it seems to make a little louder squeel when i turn the wheel slightly. any suggestions ? thanx
squeel sound under hood
Check power steering fluid first. A quick test to see if it's a belt- take a small wire brush and hold it against each side of the belt while the car is running. If the noise goes away, you have a belt issue. [img]smile.gif[/img]-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Each side meaning the grooved side and the opposite smooth side. The sides that touch the pulleys.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Originally posted by SpeedingFirebird:
You can buy belt dressing to make belt squeels go away. cheap, easy, effective. Assuming, of course, the belt does not need to be changed.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
pluse, most belt dressings say not for serpentine belts. Also, at least mine, are packed and pressed in and you cant repack them without a huge ordeal. You cant get to the bearings because they are sealed.
Take off your belt and see if there is a squeel, check your powersteering and just for s***'s and giggles maybe check your brake pads if all else fails.
Mine squeeled (sounded like from hood area when driving) when they were worn down. It also did it most often when turning.97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
Originally posted by Skinny:
Besides, dressing is just like a bandaid. It doesn't fix anything, it just covers it up. If your belt is making noise, it needs to be changed.
