i had a leaking rear main and a buddy of mine inspected my car before i bought it and told me he would replace it for $85 but i think the dealership fixed it cause i told them and i never see any oil in the garage.
Water pump dripy dripy
Originally posted by camaroincal:
</font><blockquote>quote:</font><hr />Originally posted by Distephano:
</font><blockquote>quote:</font><hr />Originally posted by camaroincal:
haha. I know but it's exactly what my water pump was doing.
Do you not watch your temp gauge?
A cracked head is NOT a direct result of a dripping water pump. If the water pump was in back enough shape that water was not moving and the car's temp went WAY to high, you could have cracked a head / blown a head gasket. You should have had an idiot light come on long before something like that happened though. </font>[/QUOTE]Woah boy calm down now lol. [img]tongue.gif[/img] All the info is here so please read it. Thanks. :rolleyes:
http://www.camarov6.com/cgi-bin/ulti...;f=16;t=002417 </font>[/QUOTE]Sorry buddy. I'm not going to go look for a thread about the same topic that you posted, just to see what your story was.
Either way, what you said made it sound like "My water pump was leaking and it cracked my heads!"
In reality, your situtaion is not really similar at all.
The reason your head gasket blew out is, like I said, you didn't pay attention to the temp guage. Your water pump was not moving coolant, because it was leaking, so your temp went way up, and you blew the head gasket. Had you paid attention to the temp and pulled over when it got that high, you would have been fine.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
So anyway, as I was driving to the tire place, the temp gauge starting going up abnormally..up to about 230 when I finally got there and turned the car off. I made sure to tell the guys there not to drive the car any more than needed becasue of the issues it was having. On the way back from the tire place as I was approaching the mechanic, the temp gauge started soaring up to the 240 range so as I was cruisin about 40 mph and only 1/10 of a mile from the shop, I turned the car off and just coasted in. Sorry for leaving that out of the main topic.<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
Originally posted by Dan Vincent:
</font><blockquote>quote:</font><hr />So anyway, as I was driving to the tire place, the temp gauge starting going up abnormally..up to about 230 when I finally got there and turned the car off. I made sure to tell the guys there not to drive the car any more than needed becasue of the issues it was having. On the way back from the tire place as I was approaching the mechanic, the temp gauge started soaring up to the 240 range so as I was cruisin about 40 mph and only 1/10 of a mile from the shop, I turned the car off and just coasted in. Sorry for leaving that out of the main topic.
[ May 24, 2004, 10:35 PM: Message edited by: camaroincal ]
The reason your head gasket blew out is, like I said, you didn't pay attention to the temp guage. Your water pump was not moving coolant, because it was leaking, so your temp went way up, and you blew the head gasket. Had you paid attention to the temp and pulled over when it got that high, you would have been fine. </font>[/QUOTE]Well maybe I should have been more thorough in my reply. But my main point was that people should know that a leaky waterpump can be a sign of other things wrong with the engine, as was in my case.
And you are wrong about thinking that I'm some ****ing idiot. I watch my temperature gauge all the time, and since I bought the car 3 years ago with 73,xxx I have kept it well maintained. But you would have known this if you would had taken the time to read the link I gave you. And please show me where I said that a cracked head is a direct cause of a blown head gasket... :rolleyes: I said that it turned out to be a cracked head after the mechanic ran some tests.
[ May 24, 2004, 10:39 PM: Message edited by: camaroincal ]
*sigh* :rolleyes:
I watch my temperature gauge all the time.
on the way back from the tire place as I was approaching the mechanic, the temp gauge started soaring up to the 240 range so as I was cruisin about 40 mph and only 1/10 of a mile from the shop
My water pump was leaking as your's was. Took it to a mechanic to a get a new one. Turns out after he installed the new water pump he ran some tests and determined I had a cracked head or bad head gasket.
If you would take the time to read the link I gave you you would understand what is going on a little better instead od talking out of your @$$.This seems awefully low to be blowing head gaskets. I bought the car in early 2001 with 73k on it and I've kept it up pretty well. Admitally I do drive a little hard, but I don't beat on it too bad. I always warm it up properly etc.
I KNOW you are not saying that when your water pump leaks, it cracks your head(s). All I'm saying is, that you seem to point fingers at your water pump right away when you find out your head is cracked. While it is true that because the water pump didn't move enough coolant to keep the engine cool, you should not have kept driving it when you saw the temp go so high, which is what will crack your heads / blow your head gaskets.
I'm not trying to start a flame war here, I'm just trying to make what I was saying clear and you are taking it as a person attack on you.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
jes its like ITS a freaking water pump
its like a rapper it flows or it don'twww.turbov6camaro.com
1997 3800 Series II Camaro
no, but seriously, my car is fine now. it was the pump leaking.
i havent been on here in a few days, i just find it funny that my leaky water pump got turned into a "crap on camaroincal" fest.
just let him go. its his car, he can do what he wants.
The water pump is design to leak when it fails. That's how you know its gone bad. There's a small weep hole on the underside of the pump where the water drips out.
[ May 26, 2004, 01:20 PM: Message edited by: Dojo2000 ]~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
what entails a water pump 'going bad'? it still pumped fine......just the seals start to go or what?
Wow, and this i did not know! no kidding! i saw the old pump had a hole in the bottom, and it looked liek thats where the stuff came from, but i didnt know. now i do! thanks.
what entails a water pump 'going bad'? it still pumped fine......just the seals start to go or what?AdvanceAutoParts.com:
In general, one of two things usually causes water-pump failure. The first is when the pump's shaft's bearings wear out. Squealing and whining usually foreshadow the bearings' ultimate demise. The other scenario is seal failure. This causes coolant to leak from the pump's "weep" hole. Coolant drips that can't be traced to the radiator hoses, overflow tanks or the thermostat housing often originate at the water pump's gaskets.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
</font><blockquote>quote:</font><hr />Originally posted by Dojo2000:
</font>[/QUOTE]Damn, man-my fault I thought that was general knowledge. Guess we should never take anything for granted huh?-235/4517 Chrome Mondera Solaris<br />-Hornet remote start-keyless entry<br />-Pioneer 8400/CD/MP3<br />-2 Audiobahn 10\'s in custom box<br />-Flowmaster exhaust-SLP CAI-*180<br /><br />Never underestimate the predictability of stupidity....Tony from \"Snatch\"
Originally posted by Christian:
</font><blockquote>quote:</font><hr />Originally posted by Ian:
</font>[/QUOTE]Damn, man-my fault I thought that was general knowledge. Guess we should never take anything for granted huh? </font>[/QUOTE]haha, yea. i guess im the only person on earth who can rebuild an engine but not figure out where the f'in coolant is comin from lol.
i was able to trace it to seal failure, but had no idea there was a weep hole. know i know.... [img]smile.gif[/img]
