Spark Plug Wires - FirebirdV6.com/CamaroV6.com Message Board
Spark Plug Wires
  • Spark Plug Wires
    been having issues with my 95 camaro v6 3.4 m5 ......i dont want to spend any money i dont have to since i plan to start swaping in my old lt1...sorry guys...
    anyway....i might buy some msd for my impala ls 2002 3.8 liter and was wondering if i could use those wires on my camaro since there pretty new...and under warranty so i can just get a fresh pair....
    i thought spark plug wires where the same just different lengths.....so can i use this wires.
    Re: Spark Plug Wires
    Yes, you should be able to.
      You should be able to use them, if they are long enough. If they are too short, then they may not reach to your spark plug.
      That's when you do a coil station swap and mount them to your firewall so you can change them easily and access them easily just by getting under your car. Even though their stock location is pretty accessible other than the one furthest back.
        yea, wires are wires...length is the only possible issue.
          they do make different types of wires but ours should be the same as the impala. like said, length is the only issue
          2000 3.8 A4 Pewter Camaro
            the length is fine but autozone sould them for 15 bucks lifetime warranty i thought they where more so i just bought them instead.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
