Idle RPM - FirebirdV6.com/CamaroV6.com Message Board
Idle RPM
  • Idle RPM
    Where does your car idle at? Mine idles at about 900 to 1000 rpm and that seems like too much to me. The plugs and wires haven't been changed in a while so I'm figuring it's that, any other possible reasons?
    1994 Camaro A4<br />Mods: Custom Intake
    I have a 1994 Firebird and it idles right around that speed. After my tune up it slowed just a bit, but not enough to really notice.
    You don't have anything to worry about.
    2000 Camaro Z/28
      Keep in mind that the stock tach is generally about 2-300 rpm's off. My car idles at 725 according to a tech2 scanner, but the tach shows about 900.
      1997 Y87 Camaro with a motor and some stuff.
        SPED 214 is right, I do not know of any F-Body that has an "accurate" Tach, any type of code scanner/computer will reveal that the actual engine rpm is almost always about 300 rpm's below what the dash shows
        Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
          According to my tach, I idle at 700rpm's. My tach must be accurate, because if it was what ya'll say, my car would be idling at like 400rpm's, which I doubt :D
          Kyle M<br />--------------<br /><a href=\"http://grdws6.netfirms.com\" target=\"_blank\">2002 Trans Am WS6</a> (silver, A4) - lid, cutout, stage 3 shift kit, 12 bolt, vig 3200, tranny cooler, bmr sfc/stb, torq thrust ii. <b>12.688 @ 106.47mph -=- 1.756 60\'</b>
            Thanks everybody, thought I had a problem there. [img]smile.gif[/img]
              Mine idles right at 1000 according to the tach.
              Matt
              [ May 08, 2002: Message edited by: 98Camaro3.8 ]</p>
              Matt
              1998 Mystic Teal Camaro M5
