Oh God...what does this look like?? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Oh God...what does this look like??
    yep yep, its not that bad to replace, i'm thinking it was around 2 or 3 hundred from the stealership, anybody should be able to do it reasonably
    • #17
      whats your oil pressure look like??
      Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
      • #18
        Oil pressure is perfect...usually right around the middle of the dial once its warm. At a cold start, it is higher - probably around 80 lbs.
        <a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
        • #19
          alright thats good then...that means you dont have any damage to your crank bearings
          • #20
            Originally posted by *K*night Rider
            ok, what if neither power window worked and there was a large dent on the rear 1/4 panel?
            itd be my car when i bought it :spank:
            <a href=\"http://photobucket.com/albums/a371/boyoi/firebird/?sc=1\" target=\"_blank\">My FireBird</a> K&N intake,Gutted cat, glass pack muffler.........Lots more to come...... <br />Getting my exhaust soon :)Rumbler Exhaust w/ Hooker\'s Headers :)
            • #21
              Question for you? When you check your oil. Were you low on oil too. I kind of have the same problem.
              • #22
                Yes, but since its a 3800, my oil is always low.
                Here is a report generated by the diagnostic tool that I bought...any thoughts?
                (PS, the P0102 code is a new one)
                (PSS, one more edit...the 3rd and 4th codes are because of my manual fan switch)
                Year: 1996
                Make: Pontiac
                Model: Firebird
                Engine: 3.8L
                VIN:
                License:
                Mileage: 107000
                Stored:
                P0102 Mass or Volume Air Flow Circuit Low Input
                P1406 EGR Valve Pintle Position Circuit
                P1651 Fan On Relay Control Circuit/Output Driver Module (Quad Driver) 'B' Quickset Fault (Saturn)
                P1652 VSS Output Circuit (1996 Corvette)
                MIL ON
                Misfire Monitoring Complete
                Fuel System Monitoring Complete
                Comprehensive Component Monitoring Complete
                Catalyst Monitoring Complete
                Heated Catalyst Monitoring Not Supported
                Evaporative System Monitoring Not Supported
                Secondary Air System Monitoring Not Supported
                A/C System Refrigerant Monitoring Not Supported
                Oxygen Sensor Monitoring Complete
                Oxygen Sensor Heater Monitoring Complete
                EGR System Monitor Complete
                DTC For Which Freeze Frame Was Stored P1406
                Fuel System 1 Status Open Loop
                Fuel System 2 Status Open Loop
                Calculated LOAD Value 4.71 %
                Engine Coolant Temp 190.4 °F
                Short Term Fuel Trim-Bank 1 -0.78 %
                Long Term Fuel Trim-Bank 1 -8.59 %
                Short Term Fuel Trim-Bank 2 -0.78 %
                Long Term Fuel Trim-Bank 2 -10.16 %
                Fuel Rail Pressure 10.7 inHg
                Engine RPM 1106.00 rpm
                Vehicle Speed Sensor 3.1 mph
                Air Flow Rate from Mass Air Flow Sensor 1.098 lb/min
                Automatic Transmission Problems:
                Check Engine Light:
                Light On Sometimes
                Driving Conditions When Problem Occurs:
                Less Than 2 Miles
                2-10 Miles
                More Than 10 Miles
                Stop And Go
                During Acceleration
                Driving Habits:
                Mostly City Driving
                Park Vehicle Outside
                Drive Less Than 10 Miles Per Day
                Engine Quits Or Stalls:
                No Symptoms
                Engine Temperature When Problem Noticed:
                Warm
                Problem First Noticed:
                Started Last Month
                Gasoline Used:
                87 Octane
                Idling Conditions:
                No Symptoms
                Peculiar Smells:
                No Symptoms
                Problem Occurs:
                Anytime
                Problems Starting Vehicle:
                No Symptoms
                Running Conditions:
                Hesitates Or Stumbles On Acceleration
                Strange Noises:
                Weather Conditions When Problem Occurs:
                Always
                Transmission Type:
                Manual
                Describe The Problem::
                Gave full throttle, engine lost power momentarily (felt like foot was popped off of gas pedal),
                MIL lit
                Previous Repairs:
                Spark plugs, wires, coil packs, radiator flush & fill, EGR replaced
                • #23
                  what scan tool are you using?? WOW
                  • #24
                    Equus 3110 Innova (just got it today):
                    http://www.amazon.com/Equus-3110-Dia...8&s=automotive
                    Not all of that came out of the tool, though...alot of that was my input into the program (ie, "driving habbits" and "problem first noticed") but it gives you a form to put that all in and you can hook it to your computer to generate those reports.
                    It also displays the Code Definition on the unit's screen while you are plugged into the car and saves that data on the unit even when you unplug.
                    The best part though, is that I NEVER AGAIN HAVE TO GO TO AUTOZONE TO HAVE MY SES LIGHT TURNED OFF!!!!
                    As a side note: I will be getting rid of this car in the next two days. I have lined up a loan and already know what car I am going to get.
                    I went outside tonight to try to clean out the EGR ports and while trying to unscrew one of the slinky-looking tubes from the exhaust manifold, the rusty screw snapped in half...so my EGR valve isn't even hooked up all the way now.
                    Hopefully Carmax won't notice that when I bring it in to them to get rid of it.
                    • #25
                      The ironic thing is that I'm looking at new cars and my top pick (2003 - 2005 Audi A4 1.8T Quatro) has an "oil sludge" issue if people don't change their oil enough (Audi recommended 10,000 miles between changes, so its really their fault).
                      So, in other words...oil is ruining my automotive life
                      synthetic oil is a must with the 1.8t... i wouldnt buy anything with that engine in it if it had ever touched anything else... it doesnt really matter even if you change it every 3k... conventional oil will ruin that engine...
                      -Chris<br /><br /> my sooooold car... <a href=\"http://www.cardomain.com/id/bigchrismayne\" target=\"_blank\">http://www.cardomain.com/id/bigchrismayne</a>
                      • #26
                        Right...that's what I figured out. Buying one used, then obviously becomes scary as most people just go to jiffy lube and ask for the special of the day.
                        • #27
                          I just went out to change my oil and opened the filler cap and saw this:
                          https://webspace.utexas.edu/woodas/Pics/Neck.JPG
                          https://webspace.utexas.edu/woodas/Pics/Cap.JPG
                          I haven't drained the oil yet...
                          I'm guessing this is an intake gasket problem?
                          That looks like an oil filler neck and the associated cap, most commonly used to add engine oil to your engine.
                          • #28
                            So the verdict of this problem is coolant leaking into the oil it seems right? Is the original coolant being used Dex-Cool or regular Prestone Green? I am only seeing guesses and not the main root problem being pinpointed, maybe the resident GM benchtech here is on the money but I am not convinced. I know, it will take time to find the culprit but the accompanying pictures seem to be a trend in our 3.8L motors if I am not wrong. Another strike for Dex-Cool because I have yet to see green coolant look like that.
                            I would expect some part numbers displayed here to help the dude out and a long list of items to remedy his problem. A trip to the dealership would most likely fix it for an outrageous cost and we would eventually see the list of actual parts used to fix it however I think it would be a good idea for this and any F-Body enthusiasts forum to start displaying more part numbers here to help each other out, plus save us a lot of cash in the process. There's gotta be somebody out there purchasing GM parts or cross referencing from NAPA Auto for example.
                            Just my .02 cents, back to the garage and into my '88 Z-28. Royal Purple oil change, plugs, wires and coil.:eek:
                            Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
                            • Andy H
                              Transmission removal help!!
                              by Andy H
                            • 2.8 Bird
                              Abs inop
                              by 2.8 Bird
                            • fishin
                              by fishin
