what year dash and interior pieces will bolt up in my 96? are the bags the same? i heard the bag modules from the v8 and v6 are compatible with eachother is this true?
will a dash and other interior piec es from a 00 work in a 96?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
i need a camaro bag thanksLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
The dash is the same from 93-96 for camaros. Either v8 or v6 will work. In 97 on up they changed. I do believe the new ones will fit, just unsure about the gauges though as they have new gauges also, including digital milege. As far as the airbags working in the new one, I believe as long as you get the right module for those bags, that they'll work as well.1997 Camaro RS Convertible<br />White w/black top, factory chrome rims <p>Mods so far: Borla catback, Catco high flow cat,CAI,2 point STB,painted calipers and drums with caliper camaro decals,GTS blackout all the around,5% tinted windows all the way around,Streetglow red neon lights inside and under, raised camaro fill in decals on the rear, 30th anv decals, and a nice stereo system<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=275528\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=275528</a>
what other interior parts you need?? they should fit...dunno bout dash but just about everything else does.
-Equis-Car: 1995 Camaro 3.4L V6<br />Mods: K&N FIPK,3 IN. Flowmaster exaust,RKSports headers,ported/polished heads, Eibach lowering springs, RKSports preformance wing, short shifter<p><a href=\"http://www.cardomain.com/id/equis\" target=\"_blank\">http://www.cardomain.com/id/equis</a><p>Don\'t Let Coast Motor Supply Happen To You.<p>Hear The Roar Of The 3.4
