SES - CRANKSHFT POSITION CODE - FirebirdV6.com/CamaroV6.com Message Board
  • SES - CRANKSHFT POSITION CODE
    SES Came on and auto zone checked it and came up with a crankshaft position sensor code . I had them clear the code to see if it would come back on . It has not come on so my question is , could this be one of those freaky thing that happen and then won't go back on .If the code comes up shoudn't it go back on if the sensor is bad. the car seems to run good
    thanks
    97SILVERBID<br />Born to cruise
    Have you replaced your PCM lately?
    After you replace your PCM you have to do a crankshaft position relearn procedure.
    That is to sync up the sensors that detect the position of the cam and crank.
    What was the code exactly?
    If you need a relearn procedure your SES light may blink for 10 seconds or so. The code will be P0300 which is a random misfire.
    In your case the sensor itself just might be bad.
    SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
      The only thing that I have replaced lately was the cam position sensor about 2 weeks ago
        if you replaced the sensor you will need to relearn. its dealing with very small angular measurements and each sensor is going to be a bit different.
          Chas, how do you relearn it?
            Yeah, if you replaced that sensor you need a relearn.
            You will need to take it to a shop. Most diagnostic scanners should be able to accomplish the relearn. It only takes a couple of mintues.
            I have a friend here that does them for me for free (well usually for beer) when I got my new PCM from Westers.
            A dealer would defintely be able to do it.
              CAN AUTO ZONE DO THE RELEARN PROCEDURE?
                I am unsure. You would have to ask them.
                Although, I doubt they would.
                  Called 2 dealers and got 2 differant answers . I told them that I had replaced the cam position sensor and cleared the code and one told me I should do a relearn for $90.00 and would take 45 min. to do . The other dealer told me if I replaced it and cleared the code I should be ok and didn't need to do a relearn . I am so confussed , I have had it with ******* dealers trying to hose me. I think I trust the one that said I should be ok , he is not gaining anything and could have screwed me by saying just what the first one told me
                    Actually $90 sounds right because they have to hook you up to the scanner. Places usually charge $40+ just to do that. Then they probably have a 30 min minimum labor charge or something.
                    Although the relearn only takes a few minutes. I watched my friend do it twice with his snap-on diagnostic scanner. He hooked the scanner up selected crank position relearn and it told him what to do. Involves revving the engine up to 4000rpm's or so a couple of times and hitting a couple of buttons on the scanner.
                    If you lived near Omaha I would say come on down and I am sure I could hook you up with a good deal from my friend.
                      On your crank sensor, it doesn't necessarliy mean it's a bad sensor. Because of it's location and only having a plastic cover ring protecting it, it could get dirty and stop giving readings intermittantly. This will cause the code to be thrown and, the worse it gets, might cause your car to turn off and have trouble starting from time to time.
                      95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
                        Just figured I would add into this. I need to have one done myself. I replaced my PCM when I got the custom tune from western. Now I'm throwing a P0300 code when I go WOT. I found the following link that will help you understand the relearn procedure. http://www.seattleautomotive.com/ckpdoc.htm
                        I emailed westerns and this is what they told me. "Get the crank position 'relearn' procedure done--should take the tech about
                        2 minutes. Then have all the codes erased.
                        This light is a warning only--it does not disable any functionality of the
                        car, but yes--very annoying."
                        Hope this helps.
                        Rock on, [img]graemlins/rock.gif[/img]
                        Jeff
                        2000 V6 Camaro(bought brand new)
                        5 speed
                        Project: Unreal
                        Several Mods..:naughty:plus Nitrous=WEEeee:banana:
                        2007 Suzuki GS500F :D
                        Daily driver
                        2007 Chevy Aveo 5
                        Mods K&N air filter:excited:
                        www.guardiansworlds.com
                          Thanks guys , some good information
                            posted June 19, 2004 05:33 AM Just figured I would add into this. I need to have one done myself. I replaced my PCM when I got the custom tune from western. Now I'm throwing a P0300 code when I go WOT. I found the following link that will help you understand the relearn procedure. http://www.seattleautomotive.com/ckpdoc.htm
                            Hope this helps.
                            Yeah, if you get a PCM from Wester's you need to get a crank position relearn procedure. Your car will claim to be randomly misfiring (code P0300) at WOT without it (although it appears it really isn't, just a false reading). I had the same P0300 issue and I called Lyndon (Lyndon Wester) and that is what he told me as well. A Crank position relearn does indeed clear it right up.
