hey just got in the car and noticeed the round piece around the screw above door handle was missing or fell off. does anyone know what size it is and whats its called? id like to get one from home depot so i can replace it. its on the inside, and its the screw right above the lock and door handle. its the round piece with a hole thats around the screw.
missing door screw piece
Re: missing door screw piece
i had the same problem, lost it when i took my door apart. i didnt have a screw in my garage that would fit it perfectly; im sure you could do something to make any screw work, but it would probably be ghetto. i ended up getting a body shop to fix it for me when i got my window motor installed. good luck.1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
