guys.. i'm doing my oil changes myself (i feel guilty paying the dealer hundreds for the stuff i can do on my own). Now, this is the 2nd tune up on my car since i've had it, the 1st was done by Chevy. Besides engine oil/filter, plugs, wires, tranny oil/filter, what else must be changed?? THANKS. Any special considerations since my 95 3.4l now has over 100,000 ?? ALSO! HOW DO I FIX LIFTER TAPPING NOISE without going inside the engine??
v6 maintenance..
Rotate your tires, check the tread while you're at it, check the coolant levels and appearance, and check your air filter. You'll probably want to toss it and slap in a new one.
edit- Assuming that you have a stock set-up for the intake, that is. Wouldn't want to toss a K&N. ;)
[ May 08, 2002: Message edited by: RoyalBlaze ]</p>\'93 3.4L Camaro A4<br />*Some fat P245/50R16 tires<br />*K&N FIPK<br />*Taylor 8mm Spiro Pro\'s<br />*Borla catback<br /><a href=\"http://www.members.cox.net/constantine/Project%20Royalty.htm\" target=\"_blank\">Royal Webpage</a>
You might also want to try changing your differential fluid as well as the other things you mentioned.1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
The easiest way is get a small pump made for this, but not the cheapest. Goes in the fill hole in the passenger side of the housing.
The cheapest way is loosen the diff. cover. and let the grease out, tighten it back up, and fill it up through the fill plug in the side of the housing, by holding the grease bottle sideways against it. Let the rear end/axle hang down (have the stands under a good place on the frame, not under the rear end/axle), and you will have a little more clearance for getting the bottle under there. If it needs an additive (for the lsd rear), don't forget to replace that too.
If you end up taking the cover off, you can make it easier for the next time, if you put a drain plug in the cover, or try to find a replacement cover with a drain plug.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
One other thing they recommend you change is the PCV valve. On the 3.8L series there's a little black cover on the top of your engine...right near where it says "3800 series II" Two little bolts come out and there's a little valve in there. Should just pop out for you. A little "O" ring keeps it tight so just make sure the "o" ring doesn't pop out, and if it does, put it back in. [img]smile.gif[/img] The PCV valve is really cheap, like $2.50 at Auto Zone. Good luck.
Ryan1997 Sebring Silver Metallic<br />Camaro RS A4<br /><br />Mods:<br />Aluminum Driveshaft, Z-style hood, headers, B&B Cat Back, fan switch, BMR Suspension, Silver Gauges w/blue interior lights, Clear Corners and Sidemarkers, Power antenna, 18\"x9\" OZ Superleggera Wheels
Whats the easiest way to change tranny fluid. My tranny has been making weird noises I think I need to change fluid. I have a T-5.1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
Easisest way to change your tranny fluid is to put it on a lift, take out the drain bolt located on the passenger side of tranny, let drain, reinstall drain bolt, take out filler hole bolt located right above drain bolt, refill tranny fluid with some kind of pump, and reinstall filler hole bolt.
I know you probably don't have access to a lift, but you asked for the easiest way :D its a PITA if you don't have some way of getting a lot of room under your car to work and manuveur. What I did was jack up the pass. front side of car and wiggle my way under the car to the tranny, it was a pain. Hope some of this helps.
[img]graemlins/burnout.gif[/img]~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...22 hours ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...2 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...2 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...3 weeks ago
by AZ3.8CamaroI have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...3 weeks ago
