For about the last two months now I have been hearing this rattling noise coming from around the driveshaft or exhaust of my car. sounds like Tin hitting medal or something. Wondering if its a heat shield or an exhaust leak of some kind? I doubt its the Cat, but if it is its getting replaced anyhow, for a high-flow.
Any one else have this problem? If so can I have advice to correct problem.
Thanks, Chris
Chris Reedy<br />1999 Camaro Black w/ Silver Stripes, M5. ATI Procharger w/ Intercooler<br /><a href=\"http://www.cardomain.com/id/killingtime\" target=\"_blank\">CarDomain Site</a>
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
I had two rattles but it wasn't the heatshield (though it could be in your case)
First was when the antenna was loose, but that was-of course-on the right side of the car, but was hard to detect and seemed loud.
The second was a clamp (on exhaust pipe) that was loosening. Tightened it up, no more rattles. Just make sure everythings is tightened down, no loose connections, etc.
[ March 01, 2003: Message edited by: satellite98 ]</p>
You should always have heatshields fixed. They are on there for a reason, trust me, gm doesn't put extra stuff on if they don't have to spend the money.
Unless your cat is gutted then you will want to keep the heat sheild. The internals of the cat hold heat forever and if you park in grass you run a higher risk of catching fire. If the cat is gutted then the shell will quickly cool just like the rest of your exhaust pipe.
1998 Onyx Black Camaro A4 2.75\" Custom Flomaster Catback, Removed Cat, MTI Lid, Jet Power Programmer, K&N air filter, 1LE aluminum driveshaft, maf screen removed.
There could be MANY things ratteling from under the car.
My problem was in the STOCK Y-pipe. The pipe is actually two pipes. One smaller pipe inside of a larger one. well th smaller on on the inside rusted out and was creating a ratteling sound. I bought one used, had it replaced, and everything was fine. Drove me nuts for about 6 months.
<a href=\"http://www.pbase.com/danny83/car_pix\" target=\"_blank\">http://www.pbase.com/danny83/root</a><br /><a href=\"http://community.webshots.com/user/ttopbird96\" target=\"_blank\">http://community.webshots.com/user/ttopbird96</a> [/URL]<br />00 NMB Formula M6<br />323.4HP, 336.5TQ<br />Lid, Filter, Cutout, all else stock :)<p>\"Let the modding begin!\"
Yeah I think mine might be a Y pipe now that you mention that. I always thought it was my cat, and I JUST replaced it with a high flow, and it's still rattling in the same area. I might have to check that out...thanks...
\'97 Pontiac Firebird A4 3.08/open<br />Best 60ft.: 2.411 Best 1/8: 10.262 @ 69.726 Best 1/4: 15.941 @ 87.48<br />Mods: SLP CAI, Loudmouth, Test Pipe
I found my problem and it is probably yours to.
I have a 2001 camaro. Mine was the exhaust brace with the rubber bushing. I pulled it outwards toward the tire. and it cured it. Hope it works for you b/c that S*** drove me nutz...
