I have this issue with the Reduced Engine Power/SES light,its a garentee they will come on if i dont let the car warm up,I went to get the codes and it kicked out the following 1120,1220,1221,1515,1516. Is there any way you guys can help.
Re: Reduced Engine Power
http://forum.camarov6.com/showthread.php?t=63690 start there, then use search function
im bored, so here.
DTC P1120 Throttle Position (TP) Sensor 1 Circuit
DTC P1220 Throttle Position (TP) Sensor 2 Circuit
DTC P1221 Fuel Pump Secondary Circuit Low
DTC P1515 Electronic Throttle System Throttle Position
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
what year is your car? 99+ i take it?
whats the car doing exactly? any starting problems? how many miles?more info the better.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
