ok i have a small problem about a month ago my ses light came on and i had it checked out at an auto zome and they told me that it was an o2 senser bank 1. now how big of a problem is this? as i am going to iraq in 8 days i don't have the time but my wife has to drive the car wile i am gone. so how serious is this?
o2 senser
Re: o2 senser
if the senosor itself is bad then it is less than an hour worth of work and 40 dollars to replace both sensors if you get the boschs, that is if the O2 sensor itself is bad, hope that helps :)
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
Re: o2 senser
could potentially make your car run very rich or very lean with misfires and such
Re: o2 senser
Originally posted by ninety4three4if the senosor itself is bad then it is less than an hour worth of work and 40 dollars to replace both sensors if you get the boschs, that is if the O2 sensor itself is bad, hope that helps :)
Re: o2 senser
if the sensor is bad... then probably immediately and will probably continue to get worse
I dont believe that 2 bosch sensors are only $40
Then ya gotta get the Long o2 socket which can be $10
(dont go to harbour freight on this one, go to oreillys)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: o2 senser
the O2 sensors from bosch i bought for 19.99 a piece i know cause i bought them a month ago i would recommend AC Delcos if you can afford them, they are around 100 a piece i think not sure and yes you either need a special socket or stubby wrench to install the new ones
Re: o2 senser
dont buy bosch. they are junk. spend the extra money on oem parts and get the ac delcos. bosch o2s are nothing but trouble.
Follow me!
Or this
