Gas tank? - FirebirdV6.com/CamaroV6.com Message Board
Gas tank?
  • Gas tank?
    I was running past E. so me and my dad went to fill it up. Our tanks are 16.8 gallons right.... well my dad put 17.38 gallons in my car? how in the hell is that possible
    <a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
    Well, he may have topped off the filler neck and the lines going to the evap canister thingie. Seriously though, you shouldn't be running it that low as it really stresses the fuel pump which is $$$$$.
    Or the pump at the station is lying.
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
      I had the same issue once... A hot summer day I went to shell to fill up and I had gas up between the quarter and half tank mark, thats normally... 3 to 4 gallons left for me... My tank holds 15.5 gallons and the pump went all the way to 17 gallons...
      Not the SLIGHTEST clue as to how that happened... Maybe if it were cold I could see gas contracting making less volume, requiring more gallons to fill the tank but it shouldn't be off by THAT much...
      What I would do is reset your trip the next time this happens and see how long it takes to before you're empty and divide the number of miles by your tank size giving you your MPG... If you have your normal MPG then you are fine and it was a fault at the pump... If it is a bit HIGH then the pump was correct...
      Also you can call weights and measurements...
        I've had that happen on my car and on other cars I've owned, when the tak is REALLY empty, it goes past the "rated capacity" of the tank. Maybe the manufacturer adds a little room past what they tell you just for a safety margin. Or maybe it's just when you really fill it up to the filler neck. I wouldn't worry about it.
          Yea, I thought it was 2 gallons. When it's on E, it still has 2 gallons in it right? Or is that included in the 15.5 gallons?
