Purchased Taylor 8mm Spiro's for my 3.8...Will I notice a difference? - FirebirdV6.com/CamaroV6.com Message Board
  • Purchased Taylor 8mm Spiro's for my 3.8...Will I notice a difference?
    Currently running old 8mm Bosch Wires that have been slightly burned in areas around the manifolds, and when it rains my car becomes completely sluggish... So I decided to get Taylor wires and wrap them in heat sheathing...
    Do you think I will notice any difference?
    If the old wires are cooked, it'll probably smooth things out a bit.
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
      I see, with CAI, absolutely no power gain right?
      I'm not trying to sound ricer or anything I just want to know what to expect...
        I would doubt it, but I'm running AC delco replacements which are stock diameter, so I can't really say for sure.
          The new wires will restore all the power you lost with the old ones. If you had lost a lot, you will gain a lot back. :D
          1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
            I got NGK iridium in 1st.
            They are Very Very GOOOOD:D
            And then, I got MSD8.5mm & Accel coils.
            More trq & Smooth accel.
            Im happy:)
            From Japan, 98V6 Camaro<br />Mod:Performance LightUnits & HID, FreeRamAir, FreeMAFmod, <br />Holly Air Filter, MSD wire, Accel Super DIS Coil, NGK-iridium MAX plug, Flowmaster 2.5in.<br />Sory but not good at English.
