crank position sensor install? - FirebirdV6.com/CamaroV6.com Message Board
  • crank position sensor install?
    I finally got myself a new crank position sensor and it will be here this week and what i need to know is there any tricks or info i need to know about putting in this sensor so i dont mess it up? any help is good thanks.....
    Re: crank position sensor install?
    nothing really special. your owners repair manual you bought tells you exactly how to replace it. :p
    2000 3.8 A4 Pewter Camaro
      well like i was thinking i had to take it to the dealer and do some kind of this relearn procedure or is that on the cam sensor?
        crank only
        its just straight forward on replacing it
          so i dont need to do that relearn procedure...
            I does not mention it in your owners repair manual you should have read
              I would say to do the relearn procedure
              Do you know anyone with a Tech 2 or Hp Tuners or DHP?
                The Crankshaft Position System Variation Learn Procedure should be performed if any of the following conditions are true:
                DTC P1336 is set.
                The PCM has been replaced.
                The engine has been replaced.
                The crankshaft has been replaced.
                The crankshaft harmonic balancer has been replaced.
                The crankshaft position sensor has been replaced.
                  hmmm...true. I checked SI and there it is. I assumed our cars where lucky enough to not have to relearn. I have lost some faith in these repair manuals.
                    yep, thats why i just use si
                      instructions sent
                        would it hurt if i didnt do the relearn procedure or would it run the same as it always has even with the new sensor because i put a new motor in and never did it could that be why its running rich but i only did the block?
                          i believe you are supposed to do it even if you touch the sensor because its never going to go on in exactly the same position, so it needs to learn whats what so to speak, if you find the right person at a dealer they will do it for free, i think it throws off your timing if you dont do it
                            would a bad sensor cause terrible gas mileage
                              yea because it sends the info it collects to the ignition module for spark timing and if its bad it can send wrong spark advance timing...that would be exactly why mines being changed
