I finally got myself a new crank position sensor and it will be here this week and what i need to know is there any tricks or info i need to know about putting in this sensor so i dont mess it up? any help is good thanks.....
crank position sensor install?
Re: crank position sensor install?
nothing really special. your owners repair manual you bought tells you exactly how to replace it. :p
crank only
its just straight forward on replacing it2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
I does not mention it in your owners repair manual you should have read
I would say to do the relearn procedure
Do you know anyone with a Tech 2 or Hp Tuners or DHP?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
The Crankshaft Position System Variation Learn Procedure should be performed if any of the following conditions are true:
DTC P1336 is set.
The PCM has been replaced.
The engine has been replaced.
The crankshaft has been replaced.
The crankshaft harmonic balancer has been replaced.
The crankshaft position sensor has been replaced.
hmmm...true. I checked SI and there it is. I assumed our cars where lucky enough to not have to relearn. I have lost some faith in these repair manuals.
Originally posted by BLLDOGGhmmm...true. I checked SI and there it is. I assumed our cars where lucky enough to not have to relearn. I have lost some faith in these repair manuals.
Originally posted by black95marowould it hurt if i didnt do the relearn procedure or would it run the same as it always has even with the new sensor because i put a new motor in and never did it could that be why its running rich but i only did the block?
Originally posted by 1superchevywould a bad sensor cause terrible gas mileage
