Spraying oil! - FirebirdV6.com/CamaroV6.com Message Board
Spraying oil!
  • Spraying oil!
    My car has 149,xxx miles on it and its starting to spray oil onto the side of my engine bay(drivers side). What could be the problem???
    <a href=\"http://www.cardomain.com/ride/808091\" target=\"_blank\">http://www.cardomain.com/ride/808091</a>
    Could it be youre missing the PCV valve? It may have been clogged dirty and popped off from all that pressure. If the PCV valve is stuck open at engine idle, too great a quantity of spent gases are let through. Rough engine idling and stalling can be the result. If the PCV is stuck closed, pressure inside the crankcase can build up and the gases can force engine oil up through the breather and air filter causing excessive oil consumption and a fouled intake system. The good news is that replacing the PCV valve is both easy and relatively inexpensive.
    Since most PCV valves open and close by way of a spring and plunger, they should be checked or replaced approximately every 20,000 miles, or according to your vehicle's service schedule. Since a crucial part of proper PCV system operation is a positive seal, it's also a good idea to check all hoses, grommets and clamps when servicing the valve. Always replace cracked and leaking rubber and defective clamps when replacing the PCV valve.
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
      IS it a 3.4L?
      check near your oil filter, the oil sending unit might be4 doing it(happend on my 3.4L around 120k)
