quick question - FirebirdV6.com/CamaroV6.com Message Board
quick question
  • quick question
    Yesterday I noticed that my car wasn’t heating up, no hot air at all. I looked down at my temp gauge and it was still on 100 “the lowest reading” It should have been up in the 250 rage witch is about half way or so. I did notice that every time I got out of my car for a while and started it up again that the temp would be different but then go right back down to 100. I was thinking that it could be a bad thermo but could this be a bad heater core???
    2002 Firebird<br /> <a href=\"http://www.cardomain.com/ride/2106142/1\" target=\"_blank\">http://www.cardomain.com/ride/2106142/1</a>
    if your car is going up to 250, then it is overheating.. or almost overheating.
    I would suggest getting it flushed, because the car shouldnt run that high
      could be low on coolant.
        well I should have said that it reads to 210 when its normal. thanks for the info all I'm going to take a look at the coolant then check the thermo. Thanks all.
