Underdrive Pulleys - FirebirdV6.com/CamaroV6.com Message Board
Underdrive Pulleys
  • Underdrive Pulleys
    Hey today i went out to install my underdrive pulleys and i pull out my impact gun and the bolts wont break. are they possibly reverse thread or are they standard. Thanks
    95 3.4 camaro: 3in pacesetters exhaust,Chrome intake stage 2. hopefully more to come.
    They are standard.
    ---Niño---<br /><i>95\' silver 5 spd</i>
      Electric impact?
        nah it's a snapon 3/8 impact air gun i was shocked when it didn't break it loose.
          I took mine off when I pulled my motor for rebuilding... It came off pretty easy with a large 1/2 drive socket... then just use a puller on the pulley. I'm waiting for my new ASP right now.
          anyone got any hints on how to remove the alternator pulley since it free spins.....
          \"Madison\" White \'91 Miata
            alternator just take it to autozone or advance auto and they will pull it for you. For the crank i thought you were supose to un bolt the four bolts not the center one? am i doing this wrong?
              haha, yeah you gotta do all 5 bolts I think.
                yeah all 5 need to come off I think
                95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
                  I used an electric impact wrench to take out the alternator bolt, and just a big breaker bar to get the crank bolts out. 1/2" for the surrounding crank bolts for me, don't remember what the middle one was. It was generally easy, but I'm pretty sure my pulleys kiled my Alternator, because it kiled my voltage then my alternator on my way to LA and made pull over. Cost me $150 for a new one. I do not recommend UD Pulleys for a 3.4 FBody.
                  K&N CAI, Magnaflow High Flow Cat, Flowmaster American Thunder 2.5\" Cat-back exhaust w/ 40 series Muffler (single piped exit), Pacesetter Midlength Headers, TB Bypass.<br /><br />Vid of my 3.4 - <a href=\"http://media.putfile.com/Headers49\" target=\"_blank\">http://media.putfile.com/Headers49</a>
                    have had mine on for a year and no problem. I even got a system in the car with no capicter(sp) and no problems. I have heard several people say that but I think they forget their car is at least 10 years old with the stock alt. when things get old they break.
                      i used to have one on my eclipse and the engine only lasted 2 months supposely it gets unbalanced?
                      96 Firebird 3.8L 5 spd Centerforce clutch MSD ignition dynomax dual exhaust SLP CAI
                        Did you get the bolts off yet? I did my pulleys (95 3.4) this past weekend. The alt came off with a breaker bar. The crank, I used my impact wrench set at 90 psi. Bolts came off no problem, and they are standard thread. I did soak them in PB blaster before hitting them.
                        Good luck.
                        http://www.cardomain.com/memberpage/799659
                          I installed a set of ASP pulleys on my 3.4 and i found they were pretty hard on the electrical especially the battery which I had to replace. The voltage level dropped a lot during idle and in the long run I don't think they were worth the small hp gain.
                          Newfoundlands Camaro & Firebird Enthusiast Site<br /><a href=\"http://www.nf-fbody.com\" target=\"_blank\">www.nf-fbody.com</a>
                          • Andy H
                            Transmission removal help!!
                            by Andy H
                          • 2.8 Bird
                            Abs inop
                            by 2.8 Bird
                          • fishin
                            by fishin
