i am looking to replace my stock pump in my 94 which may be the culprit to my misfire problems, i am planning on boost in the future so i figured i would upgrade to an aftermarket pump, i see that Advance auto sells a python injection pump, i dont know the flow rate or pressure rating on it but its 200 from them, the other choice is a walbro 255 lph, the only problem is where do i get one that has an install kit for my 3.4, i dont mind modifing the wiring if there are instructions involved, plug and play would be preferable however, so let me know what you guys are running and where i can get kits, thanx for the help in advance :)
Walbor or Python/Venom???
Re: Walbor or Python/Venom???
most common one for fbody guys is the walbro pump. I personally run it and it works great
where did you get it from, i know u have a 97 but the pump and tanks are basically the same as the 94's correct, also was it a plug and play deal or is there wiring needed to complete the swap?
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
zzperformance.com under the grand prix section, universal pump not the 3800 specific as that is the gp version. It was a direct plug and play for my 97
i looked on their site and saw they sell a alterantor rewire kit since the walbro draws more current, did you do this on your car or did you just replace the pump and leave it at that, any reliability issues with these pumps, thanx for all the help so far
Originally posted by ninety4three4i looked on their site and saw they sell a alterantor rewire kit since the walbro draws more current, did you do this on your car or did you just replace the pump and leave it at that, any reliability issues with these pumps, thanx for all the help so far
It is not needed at all for when you upgrade the fuel pump. It just helps if you have a big system or electronics that are taking more power. Reduces the resistance in the line. No hp gains are had from it at all.
ok i wasnt lookin for any hp gains just wondering if the new pump would draw to mny amps for the charging system, well it looks like that what ill be going with, thanx for the help :)
I heard of a problem with the standard walbro pumps running your car out of gas when you have a few gallons left in the tank. This might just be a 99+ problem though. as there is a GP over at ftv6.com for a 99+ modified walbro pump to address this problem. anyone here know the issure on these?Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
Originally posted by 99pewterv6I heard of a problem with the standard walbro pumps running your car out of gas when you have a few gallons left in the tank. This might just be a 99+ problem though. as there is a GP over at ftv6.com for a 99+ modified walbro pump to address this problem. anyone here know the issure on these?
