gasket prob - FirebirdV6.com/CamaroV6.com Message Board
gasket prob
  • gasket prob
    does any one know if GM makes a complete gasket package for a 199 firebird
    1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
    The generic cylinder head set set for 93-97 v6's is HS9917PT depending on certain criteria append a 1 or 2 to the end of this number (I don't know the difference between the two) more info can be found here:
    https://www.rockauto.com/dbphp/dbpag...ASKET-HEAD+SET
    <a href=\"http://www.digitalaudiophile.com\" target=\"_blank\">www.digitalaudiophile.com</a>
    • Andy H
      Transmission removal help!!
      by Andy H
    • 2.8 Bird
      Abs inop
      by 2.8 Bird
    • fishin
      by fishin
