key stuck in ignition - FirebirdV6.com/CamaroV6.com Message Board
  • key stuck in ignition
    did a search on a couple of incidences where people got their key stuck in their ignitions ... don't know exactly how they resolved their problem, so i'm posting.
    ok ... this is exactly what happened.
    went to move my car
    stuck the key in the ignition
    put it in drive ... went like 20 feet into my parking space
    ... and long and behold ...
    the key doesnt come out of the driving position.
    yeah ... so called the 1-800 number for chevy and they told me to take the fuel pump fuse out along with the ignition fuse so the car will turn off ... and now im basically stuck with a key that doesn't want to come out of the ignition.
    any ideas on how i could take the key out?
    i've tried moving the steering column with the tilt wheel feature / putting it in neutral and try to move the ignition and the key ... still won't budge / used all my tools to just yank the dang yo thing out ... but still no success.
    help ... me!
    99 Camaro RS - 3.8L V6<br /><br />Modifications<br />Exhaust: Magnaflow OBD-II High-flow Catalytic converter / Magnaflow catback exhaust<br />Intake: Shaved Airlid / 3\" PVC tub<br />Suspension: V8 springs / DeCarbon shocks / 32mm 1LE swaybar / 19mm rear swaybar
    I had the exact same problem, remove your shifter knob then remove the housing under it.
    If you slightly push down on the top of the shifter you can see when you push it, it kind of "pumps" some sort of cylinder. Mess around with the cylinder and try to pull it with your hand.
    Once your there it will make more sence. TO my car this cylinder was just kind of stuck and i just tapped it and it unlocked the key.
      CAMAROWIDBASS your a smart man, you gave the best advice, this happpen to me at work on night after that day i was messing with my center console.
      It all came together after 20 minutes...
      Trust me i was so relieved that it wasnt the lock Cylinder..
      New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
        got in there ... checked the pump thing you were talking about ... and there was actually 2 pumps. both of them were working fine from what i see. is there any other reason why my key might be stuck?
          It wont let pull the key put? wiggle the parking brake sometimes it doesnt lock very good and its still in nuetral!! then the car wont let u take it out! just try and wiggle it a bit. It happened to me before and i did that and it worked u will here a little click if it works!
          !!No Worries!!<br /><br /> <a href=\"http://www.cardomain.com/memberpage/515424\" target=\"_blank\">http://www.cardomain.com/memberpage/515424</a>
