ok so when i get really low on gas my I get a whine sound from the gas tank. So it must be my fuel pump. Does that mean it is bad or what. It also spounders real bad from a start. Could it be my injectors. or what. If it is my fuel pump could i replace and how expensive is it.
HELP fuel pump?
It is really a bad idea to let a car w/ an electric fuel pump to get under a quarter of a tank of gas. That is the easiest way to ruin a fuel pump. The sound you hear is always made by the fuel pump. You can not hear it unless you get really low on gas. Before you decide to change your fuel pump you should check your fuel pressure. If its within specs, don't worry about it and keep some gas in your tank. If not, them change it. Also monitoring your fuel pressure while driving will give you an indication if your 'spoundering' problem is fuel related.
Jim
And out of curiosity, why did you remove your MAF? How did you compensate the missing info in your computer? That just sounds like a really bad idea since the computer has no way to measure the amount of air for a proper air/fuel ratio.
Jim
A loud fuel pump is a sign that it's about to take a crap on you. Running less than a 1/4 tank of gas (acutally less than 1/8 tank, because of the gauge) creates fuel starvation and a dry-sump situation. Dirt, grime, or whatever else in the bottom of your tank may be sucked up into the pump, and destroy it.Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...1 week ago
I stopped driving...2 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...3 weeks ago
