Hey, just bought an ASP crankshaft pulley off summit....anyone know if i'll need a different size belt to install it? Or if i should just buy another one anyhow (car's at 88 thousand miles) Is there any kind of performance belt out there? thanx
new serpentine?
Re: new serpentine?
As far as replacing them, the only time you need to replace the serp. belt is when it's frayed/cracking, and that can be determined by a quick visual inspection. There are some Gatorback belts that are supposed to reduce slipping, but you need to be careful when going there...don't want to create parasitic loss
Re: new serpentine?
Originally posted by Smoke PantherAs far as replacing them, the only time you need to replace the serp. belt is when it's frayed/cracking, and that can be determined by a quick visual inspection. There are some Gatorback belts that are supposed to reduce slipping, but you need to be careful when going there...don't want to create parasitic loss
Re: new serpentine?
If your current belt is frayed/cracking, stock replacement should be more than adequate, however, i'm not sure if it'll be the right size for that fancy new pulley you just boughtLast edited by Smoke Panther; 03-05-2007, 02:37 PM.
Re: new serpentine?
If your lucky the belt tensioners will take up the slack! :D hopefully nothing is too loose.MSN: inynn666@hotmail.com<br />1996 Arctic white -3800-<br />Pacesetter Headers & Y-Pipe, CAI, LS1 Dual Exhaust, LS1 Driveshaft<br />*15.17 @ 95MPH*
I stopped driving...3 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
