I've been into the city for the past few days doing christmas shopping and every time I've noticed that I start running a little hot when waiting at long red lights and in traffic jams. When not moving, my temp climbs up to about mid way but as soon as I hit 50ish it goes right back down. Is this normal? I just had my oil changed and have had the car for only a year, perhaps its time to refresh the dexcool?
it would be a good idea to check your fans and make sure they are working. checking your coolant wouldnt hurt either just cause
just read you post again, its going half way, so to 210? going to 210 is fine. but if you dont get up to speed, does it keep going past 210? if so, if it contines to go up, i would check your fans. other than that, this sounds like a normally operating cooling system.
Sitting still results in no airflow to keep things cool, so the temperature will climb until the fans kick in. You'll always run cooler while driving than sitting.
Originally posted by BLLDOGG: </font><blockquote>quote:</font><hr />Originally posted by viper04af: flush the system put a 180* thermo in there and replace your water pump
are you serious? </font>[/QUOTE]water pump should be replaed every 80k miles dexcool where's it down badly
www.turbov6camaro.com 1997 3800 Series II Camaro 4600 Stall for my ride to the mall :chug: 7.18 @ 99.77 1/8 -1.8x sixty (current quickest v6 fbod) 11.23 @ unk 5 1/4 - 7.19 1/8 - 1.83 sixty
Sounds like its normal, most vehicles do that anyways. Unlike cars/trucks though, I cant let my dirtbike sit and idle very long at all. It doesn't have a fan on the radiators so I have turn off the engine if I'm going to sit still for more than a minute or two.
if your going to flush it, flush it good and go back with the Green stuff. [img]smile.gif[/img] Oh, and i agree, if you going to work on your cooling system.. go a head a change you water pump, and tstat. Im just saying what i would do.
