temp going wild - FirebirdV6.com/CamaroV6.com Message Board
temp going wild
  • temp going wild
    ok so i sat in about 30 minutes of traffic today and then stopped at advanced to get some cleaning supplies to clean the car this weekend.
    came back out to the car and radiator fluid was in a little trickle on the ground, i got it home and filled it...still can't figure out where it was coming from.
    on the way home i noticed the temperature gauge was going from 190 - about 220 every couple of seconds, like it would go to 190 stay there for like 5 seconds then switch to 220...it did this the whole way home.
    is my car trying to tell me the thermostat is dead and i need to replace it? i have no idea what's going on and really can't afford to have this motor take a crap on me when i've got my build coming this summer...
    anyone got any ideas?
    1995 Firebird 3.4 V6 M5<br />-Firehawk 17x9 w/275/40/ZR17, flowmaster 80s, high-flow cat<br />*new* BMR lowering springs, Bilstein shocks, WS.6 sway bars, polyurethane bushings.
    Re: temp going wild
    swap the thermo
      Re: temp going wild
      i'd get a new thermo... my temp was jumping back and forth quickly and it was due to a low amount of coolant... filled it up and it fixed the problem. But doesn't sound like thats your problem
        Re: temp going wild
        yea i'm going to do that tomorrow, i got it in the garage and took off the intake tube and started taking the old one out...
        a buddy of mine said it might be the water pump...i bet that's hard as shyt to replace...
          Re: temp going wild
          I had that same problem and it was the water pump. and yes it is hard as shyt to replace.
