Changing Fluids - FirebirdV6.com/CamaroV6.com Message Board
Changing Fluids
  • Changing Fluids
    My car is nearing the grand 100,000 mark and I've decided to change all the fluids and filters. I've never tried any of these (at least on my firebird) which ones are easily done by myself...and which ones would be better off with a mechanic?
    Flush and Refill:
    Coolant
    Oil
    Rear Differential Fluid
    Tranmission Fluid
    Top Off:
    Power Steering Fluid
    Break Fluid
    Replace:
    PCV valve
    Spark Plugs
    Fuel Filter
    Oil Filter
    Trans. Filters
    any insight would be great because i have no problem attempting these things myself or with a friend who knows much more about cars than me.
    Re: Changing Fluids
    You can do yourself:
    Oil
    Rear diff
    PCV
    Spark plugs
    fuel filter
    oil filter
    I would let a shop flush out with their systems the:
    coolant
    tranny fluid w/ filter (has this ever been done to the car?)
    power steering
    Brake fluid you could probably do, but why not do it when you get some new brakes or something?
    http://www.bowtiev6.com/
      Re: Changing Fluids
      Oil
      Rear diff
      PCV
      Spark plugs
      fuel filter
      oil filter
      coolant
      power steering
      honestly i didn't even know there was a tranny filter so.... the previous owner might have done it (i bought it half a year ago) and i might get some new brakes put in so i'll have them do the fluid then i guess. Thanx for the tips, now i know what i can do myself to save money and learn how to do it (which is always fun and useful)
        Re: Changing Fluids
        oh one more Q...would u suggest synthetic oil?? and are there any types of fuel or oil filter that are better than the rest
          Re: Changing Fluids
          I cannot answer your question about synthetic oil, but one word of advice that I always heed is when buying a used car, always assume the previous owner did nothing about fluids and filters. What I mean is, when you have the Transmission fluid changed, have them do the trans. filter too. Then the following year, have the trans. flushed (they do not change the filter when they "flush") - Paul
            Re: Changing Fluids
            yeah i hear what your sayin....thats why i've decided to change all the fluids and just kinda go from there
              Re: Changing Fluids
              Do you have a manual transmission or automatic? Manual trannies do not have filters.
                Re: Changing Fluids
                You can do all of these on your own, just get a HAynes or a Chiltons.
                '66 Ford SOLD
                  Re: Changing Fluids
                  I have an automatic trans, and i do have a haynes manual...i was skimming through it and it seems like it will be very helpful when i attempt some of these changes...
                  Just wondering... Say i changed my oil, oil filter, trans fluid, trans filter, fuel filter, and pvc valve how much would that run me off hand?
                  thanx
                    Re: Changing Fluids
                    thanx
                    All depends on the quality of the stuff you buy. I did all that and my powersteering after my swap and it was about a $60 bill.
                    '66 Ford SOLD
                      Re: Changing Fluids
                      did you just go to an auto store and tell them what you needed?
                        Re: Changing Fluids
                        first off.. please tell me you have the oil changed before and this isn't your first time... the rest go with rs4life except the plugs... that be a pain.. I tried the plugs and gave up and I would like to think my mechanical abilities are fairly good.... do you know what a shop does for those typically? they drop the engine... thats how bad it is... good luck man
                          Re: Changing Fluids
                          No I certainly had the oil changed, but now i want to do it myself..... I can't believe they have to drop the engine to get the plugs.... i've heard just jacking the car up will help
                            Re: Changing Fluids
                            Flush and Refill:
                            Coolant
                            Oil
                            Tranmission Fluid
                            Top Off:
                            Break Fluid
                            Replace:
                            PCV valve
                            Spark Plugs
                            Fuel Filter
                            Oil Filter
                            Trans. Filters
                            You can do all of these yourself; however, since you are just learning, I would start with the easier ones: oil, rear diff, PCV valve, and PS fluid. Coolant can be a touch tricky, but there is SO much info out on the web, you can do this too. Instructions have been posted on here many times.
                            Tranny fluid/screen, spark plugs, brake fluid flush I would shop out for now until you get more experience.
                            Oil filter - honestly, if the car is running fine. Leave it and do it when you get more experience.
                            50% of the world will disagree with me on this one, but stick with dino oil. Since your car is older, synthetic oil may clean your seals too well. What happens is, over the years, gunk and stuff actually plugs leaks in your seals. Synthetic oil cleans out this gunk thus leaving minor leaks. Again, tons of info on the Web.
                              Re: Changing Fluids
                              they do not drop the engine. I dunno where you got that crazy info from but there is no way they go through that much work to change spark plugs. I did all mine without dropping the engine, it just takes patience and time. Some of them you have to get from the top and some you have to get from the bottom.
