I was wondering how I can get my car to run cooler.I got the hypertech programmer,set it to 160,got the 170 thermostat and it still runs at about the same temp.Does anyone know any tricks to make it run cooler?
cooling
Re: cooling
stock runs around 210 so he isn't running hot at all. With hptuners I changed my fan settings and I usually see 178* coolant temp now.
Re: cooling
right if you are highway cruising it is going to be lower, but around town and stuff stock will get to 210 before fans kick on
You can also make a manual fan switch or buy a manual fan switch to turn the fans on sooner and keep it cooler.
Re: cooling
Originally posted by 97rs4liferight if you are highway cruising it is going to be lower, but around town and stuff stock will get to 210 before fans kick on
Re: cooling
thermo swap is a 10 minute job. just make sure to bleed the air out after you are done. Or you will panic when you see your temp rise way high, lol
