coolant/seafoam question - FirebirdV6.com/CamaroV6.com Message Board
  • coolant/seafoam question
    looked under theengine toda nd a huge wet spot of what i think is radiator coolant. watthe hell is the deal wit that???
    what is seafoaming? how do u do it?
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    <blockquote>quote:</font><hr>Originally posted by FuryCharger:
    looked under theengine toda nd a huge wet spot of what i think is radiator coolant. watthe hell is the deal wit that???<hr></blockquote>
    :eek: That's some spelling! ;)
    Was it coolant or just water from the A/C. Could have just been water, which would be completely normal.
    what is seafoaming? how do u do it?<hr></blockquote>
    Sea Foam is used to clean out all the junk that builds up inside your engine. You pour some into your vacuum line and it gets sucked up into the engine. Do a search and you'll find a bunch of posts about it. Many people have been posting about it lately.
    Matt
    1998 Mystic Teal Camaro M5
      naw its definitely coolant or some other thing. its got a distinct smell and drips everytime i park...
        What year is your car if its a 96 or 97 i would almostc bet my paycheck for a week that it is a combination of WATER PUMP and/or Intake/Head Gasket..
        Try the water pump first if its antifreeze $40 and about 20 minutes to change if that doenst totally fix it get a few cases of beer the gaskets and prepare to cus alot !!!
        AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
          it was the damn water pump. dont know hwot to change that myself, looks like ill drop it off at the shop
            IF you havent already dropped it off DONT !!!!! if you are at ALL interested in learing about cars and how to work on them yourself this is a REALLY EASY thing to do and start learing...
            Tools needed are.
            15mm Socket
            12mm(i thinkk)
            Wrench
            3 inch extension
            razor blade
            1)Let the motor cool COMPLETLEY
            2)Loosen tensioner by pushing counterclockwise.
            3)Remove Belt
            3.5) Remove water pump pulley ( 4 bolts )
            4) Remove both hoses going into and out of water pump ( At this point antifreeze will spill out)
            5) Remove the 7-9 bolts holding the pump in ( 2 different sized bolts hold it in )
            6) pull water pump off ( takes a litle effort)
            7) clean off gasket mating surface down to BARE METAL be EXTRA careful not to gouge the alluminum though!!!!!
            8) Replace reversing these directions and fill the coolant back up !!!!
            it took me 30 minutes and $40 ..... at most it will take you 2 hours and probally save you $100 !!!!!!!
            if you need any more help shoot me an email [img]graemlins/burnout.gif[/img]
            [ June 02, 2003: Message edited by: whtefbrd96 ]</p>
