washed my motor with simple green and now it acts as if its missing on one cylinder. i changed the plug wires and tried plugs too. what should i do? ive checked all the connections i can find and made sure there all clean. It ran great before i did the wash. i put an oil pressure sending unit on it before i washed it too.(old one was junk) does that have anything to do with it? alternator is charging just fine also. ive checked over an over an over everything. someone please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!:mad:
washed engine and now she runs terrible! HELP
Re: washed engine and now she runs terrible! HELP
yup, doesnt take much to mess up electrical stuff on a car. have them checked.
Follow me!
Or this
I went through the exact same situation recently. It did turn out to be moisture with the coil packs. All I had to do was pull the plug wires at the coil packs, spray both with electrical cleaner (I also took the opportunity to clean some of the corosion on the coil pack terminals) and the problem was solved. Also, be sure to disconnect the batter before doing all this and keep it disconnected for atleast 20-30 minutes. Let us know if this solves your problems. Good luck!
Check all sensors and coil packs, making sure none of them are wet or holding water. Especially your spark plugs
Getting sensors wet is a bad thing and you don't want to have that happen. That's why I don't see how people are brave enough to wash their engine bay unless they do it by hand................to all of you that have ever sprayed down your engine bay with water (the complete thing) and it still ran fine, I commend you and call you lucky.
Originally posted by VanquishCheck all sensors and coil packs, making sure none of them are wet or holding water. Especially your spark plugs
Originally posted by 97rs4lifeI spray mine down in the car wash, but I put plastic bags over the pcm, coils, air filter, and other exposed electrical stuff. Never had problems
ok guys im not stupid- i did cover alot of sh*t up before i washed it. ive washed every motor on every car ive ever had and never had any probs. my next question is -is that a coomon prob? coilpacks going out from water? i checked all my wires with a spark tester and its weak spark on #5. plugs and wires have been replaced. so im thinkin its that one coilpack. thanks for all your suggestions- ive tried most all of them-let me know if you guys can think of anything else
coil packs going out due to water is a very common problem on our cars due to the position of them right under the cowl. So yes they are known to go out
well hell-advance sells one(coilpack) for 23 bucks-im broke for like 2-3 days tho. and my freakin car is only runnin off of 5 cylinders-what a bummer. is it gonna hurt it to drive to work? i dont think it will but id like to hear what you guys think
There is a carwash by my house that sprays water up under your car as you pull in to the wash station. The two times (won't do it again) that I've been there, my CEL comes on as soon as I hear that water hit the car and it will sputter giving me a cyl 4 misfire. After a few mins of driving it does go away.
Originally posted by VanquishThat' s different though. I've seen people dumb enough to just pop their hood and go at it with the degreaser at the car wash without covering any of the electrical up. At least you use your brain to cover up the important things that would cause a car to run like crap if they got wet.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
