3.4 air temp switch - FirebirdV6.com/CamaroV6.com Message Board
3.4 air temp switch
  • 3.4 air temp switch
    what is the function of the air temp switch?what are the symtoms of it going bad?
    Re: 3.4 air temp switch
    What's the air temp switch?
      its located by the idle air control in the air filter duct to the throttle body
        its the intake air temp sensor and you not really going to notice anything if its bad. the only thing would be if you shut the car off in 100 deg weather and then started it back up in 60 deg weather it would tke 5 seconds longer to get the proper a/f ratio if you could magicaly start it in closed loop mod
        you can test the sensor with an ohm meter. you can find the specs in mitchell on demand or alldata i do believe.
          cool-very informative thanx bro!
            no prob
