So guys heres the situation. Im getting the hard shift from 1st to 2nd, i searched and found most common fix was a sonnax kit, now i called around here and a couple guys suggessted the Younger Shift Kit (sorry if i spelt it wrong). My question is will the Shift Kit fix it or should i just find a shop to install the Sonnax Kit.
Also i put this in Gen Tech cause i wasnt gettin much feedback in the Drivetrain section
Thanks i trust u guys more with my car then some of these thieves around here.
never heard of the younger shift kit, my brother had the same problem and the trans shap installed the sonnax kit for 300 out the door. If the younger kit is the same then I don't see why it would matter
