t-top adjustment... - FirebirdV6.com/CamaroV6.com Message Board
t-top adjustment...
  • t-top adjustment...
    I've been searching for a while now and can't find any information on how to adjust the t-tops... The one on the driverside makes noise every time I hit a bump in the road. Is it possible to adjust it to make it stop making noise???
    Re: t-top adjustment...
    Same type of thing happens to mine but I have no Idea. I just ignore it or turn up the music more. Besides with the warm weather comming soon I dought my t-tops will be in very much.
      Install subframe connectors. They will eliminate almost all creeks & rattles that are common with camaro's & firebirds.
        strut tower brace and subframes is aboutall u can do...unles u wanna take apart ur ttop in hopes of fixing it
          dude, this is what u should do/try. take off the top. remove the screws holding the molding to the car. there is a 10mm or 8mm nut in there that u can tinker with and move the assembly around. loosen it, take it off it u want to. careful when taking it all off, i remember it being tricky when i put it back together. so maybe dont remove it. so mess with that. use your noggen.
            just what he said/\. it's not hard to fix or put back together. just watch what your doing. don't want to lose a t top going about 75 down a freeway
            WAWA-A-HOLIC
              Mine does the same thing. I am looking at subframe connectors with the strut tower support.
                what is a good brand of sub frae connectors. I looked on ebay ane there are the tubular and the triangular style. Also what is better weld in or bolt in. just asking for experinced suggestions.
                  This actually belongs in the Suspension category, but...
                  K design SFC's are about the best you can buy. Bolt in's are easy to install, but weld in's offer (by far) the best all-around stability.
                    I found that if you take the top out and the A-Pillar trim off you can adjust the "Pin" bracket, with a little patience my top is now squeek free. Probably took me 10 minutes tops.
                      Is it like a sqeaking noise? Because I've been getting a sqeaking noise coming from behind my left ear when i hit a bump and it pisses me off.
                      2001 Firebird 3.8L
                        Go to HomeDepot...spend $2.50 for a bottle of silicone spray.
                        Spray all weatherstripping with silicone. That could do it.
                        Phil
                          moving to general tech.
                          Visit My F-Body Page
