I've been searching for a while now and can't find any information on how to adjust the t-tops... The one on the driverside makes noise every time I hit a bump in the road. Is it possible to adjust it to make it stop making noise???
t-top adjustment...
Re: t-top adjustment...
dude, this is what u should do/try. take off the top. remove the screws holding the molding to the car. there is a 10mm or 8mm nut in there that u can tinker with and move the assembly around. loosen it, take it off it u want to. careful when taking it all off, i remember it being tricky when i put it back together. so maybe dont remove it. so mess with that. use your noggen.Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
Originally posted by Brian99what is a good brand of sub frae connectors. I looked on ebay ane there are the tubular and the triangular style. Also what is better weld in or bolt in. just asking for experinced suggestions.
K design SFC's are about the best you can buy. Bolt in's are easy to install, but weld in's offer (by far) the best all-around stability.sigpic
moving to general tech.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...5 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
