radiator flush - FirebirdV6.com/CamaroV6.com Message Board
radiator flush
  • radiator flush
    so this weekend i want to flush my radiator because im pretty sure the owner before me never did one and i want everything flushed out.
    i read the engine about the dex cool stuff but it tells me to refer to the user book but i dont have one, so what should i do? i know how to drain it, but when i fill it back up, do i just fill it up with dex cool until it over flows? because on the bottle it says not to add water.
    Re: radiator flush
    What year? If you are 96+ you need to use a 50/50 mix of Dex-Cool and distilled water. It is best to buy it pre-mixed.
    Where does it say to not add water?
    Raven
      Re: radiator flush
      its a 97.
      and it says it right on the bottle.
      "do not add water"
        Re: radiator flush
        ohhh im sorry, i just went outside and checked, the one we have already is pre-mixed... haha thats why it says dont add water. ok, well with that what do i do? just fill it to its fill to the top of the rad. cap?
          Re: radiator flush
          then you bleed it via the bleeder screw
          2000 3.8 A4 Pewter Camaro
            Re: radiator flush
            how good does that even clean out ur radiator if u just put new coolant in and then run it and drain again and refill?
              Re: radiator flush
              i flush mine. never had a problem. just added new fluid when i stopped seeing orange $hit. now she is nice and yellow-green!
              WAWA-A-HOLIC
                Re: radiator flush
                yeah im going to make sure mine is fully flushed. its very rusty lookin now. once it all comes out im gonna stick my hose threw it and let it run right out the bottom for a few minutes to clear it up even more, then add the dex cool. probly this weekend this will get done, and maybe sea foam, if not, next weekend for sure.
                  Re: radiator flush
                  I use that Prestone flush kit which ties into a heater hose and lets you hook up a garden hose and pump water in there. Never had any leaks or other problems from it.
                  2001 Pewter Firebird Y87, M5
                  Go Sabres!
                    Re: radiator flush
                    just out of curiosity where are you gonna put all of that antifreeze and dirty water i want to flush mine but dont know what to do with it????
                      Re: radiator flush
                      im gonna drain it into one of those containers i use to catch oil when i change my oil, then pour it into like a empty milk gallon and bring it to my school and probly dumb it in the used anti freeze tank... (if im not too lazy)
