Does anything need to be moved to replace this sensor? I haven't really looked at it, I just replaced the cam position sensor, and it killed some of the miss in my motor. I have a feeling 194k miles, this sensor is going too. :)
Crank Position Sensor
Re: Crank Position Sensor
yes and no....on my car there is two crank sensors....the 3x sensor on the side of the motor on the passenger side comes off right away....the 24x senor right behind of the harmonic balancer need the pulley/harmonic balancer to be removed....just make sure if you car will relearn on its own the new sensor or if you will have to take it to get relearned.
Originally posted by BEASTyes and no....on my car there is two crank sensors....the 3x sensor on the side of the motor on the passenger side comes off right away....the 24x senor right behind of the harmonic balancer need the pulley/harmonic balancer to be removed....just make sure if you car will relearn on its own the new sensor or if you will have to take it to get relearned.
if its OBDI you wont have to get the relearn procedure but if its OBDII you will im not entirely sure what it is just thought id let you know
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...4 weeks ago
