i finished the conver. and now the drivers side leaks a little. in the front of the window, where the t top meets the weather striping. i knnow that this is something that alot of you have. how do i fix it.
leaking t top
black RTV sealant between the weatehrstripping and the frame. It channels the water into the little plastic clip which channels it through the weatherstripping and down into the door.
Htere is some from the factory but obviously since you do not have factory installed weatherstripping, you don't have the small seal.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
I'll bring over that stuff this weekend (if you want) and give it another shot. If that doesn't work, we'll need to pry the weatherstripping up and put a little bit more support at underneath to lift it up so you'll get a better seal. Something has got to work!
Give me a call. I am still on daywork until Monday, Jan 2nd.sigpic
got any pics of the exact location of the leak?-Rick<br /><br />Bright White \'95 Firebird Convertible 3.4L A4 - Flowmaster American Thunder Cat-back, Zexel Torsen Posi-traction, Black Checkered Stripes, Clear Corners, Misc. Appearance Mods.<br /> <a href=\"http://www.cardomain.com/ride/2077741\" target=\"_blank\">http://www.cardomain.com/ride/2077741</a> <br /><br />AIM ID: AxSlane
just to try and see if it works . put sum grease in that channel . whipe it in there . see if it makes a seal . you can close the gap in the t-top to weatherstrip by adjusting the front aduster down by removing any shims you installed . when i converted it took several hours the get it right . let me know if it works
