Seriously need help with problem!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Seriously need help with problem!!!
    Ok, I was cruising in my 95' Firebird 3.4 the other day and it ran absolutley fine. I park it...then get it out again the next day and I'm having all kinds of problems.... Low engine oil light came on even though there engine oil level is slightl above full......the oil pressure dropped to around 20psi when car is warmed up.....loss of power on mid-topend....and all of a sudden my battery drained on me tonight......it keeps burning through air pump fuses as well...and the exhaust seems much quieter than normal....I don't f#ck!ng get it......just by sitting overnite the problems came up...The engine sounds fine..no knocking or ticking of any sort...no oil leaks anywhere...Please help out guys..I love this car and don't want anything seriously wrong to happen to it..I was told it might be an 02 sensor but I'm not sure....or possibly an IAT sensor....what do you guys think???
    Thanks, Shane
    Re: Seriously need help with problem!!!
    Based opn everything that suddenly went wrong I would go with electrical but that would be hard to diagnose over a comp. If you continue to blow fuses that to me would indicate a short. That in conjunction with the other stuff popping up leads me to shorts somewhere in the system.
    Let's flip a coin. Heads I get tail, Tails I get head.
      wife's car had an alternator that was going out. all the lights flickered, hell even the power door locks where locking and unlocking. check your voltage and amperage
